high-watt systems rob horsepower?
zhalverson
Copper - Posts: 180
Posted: May 18, 2006 at 1:25 AM / IP Logged
Ok, this is just a question out of curiousity.  I noticed that 1 hp=746 watts.  Supposing you were running 1500 watts rms you could assume that it is going to be more like 2000 watts drawn because the amps effeciency, or lack there of.  So could you safely say when you have the stereo tapped out you are going to hurt the available horsepower by about 2.6 ponies using this example?
jeffchilcott
Platinum - Posts: 2,483
Posted: May 18, 2006 at 2:05 AM / IP Logged
I havent noticed any lack of horsepower from installing a bigger alternator if thats your question...besides that the electrical system in a car really shoundt add any horsepower nor take anyaway
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
luckydevil
Silver - Posts: 365
Posted: May 18, 2006 at 7:45 AM / IP Logged
I'm studying for the MECP Advanced Installer test right now and the book actually talked about that.
It basically says that a 200-ampere high output alternator requires about 7-8hp from the engine to make the full 200 amps at 14 volts.
haemphyst
Platinum - Posts: 5,059
Posted: May 18, 2006 at 8:57 AM / IP Logged
Absolutely. You can't get energy (the power for the system, including all waste in the form of heat IS energy) from nothing. The alternator is connected to the crank of your engine BECAUSE it has to rob power from your engine to work.
Larger alternator, more power "borrowed" from your engine. However, an alternator is AT BEST 66% eficient at converting input to output, so 746/.66=1130 watts of MECHANICAL energy in, or 1.5HP, just to convert the mechanical to electrical, and generate 746 watts. These losses include the energy required to set up the field in the stator, also. 200A*14.4v=2880 electrical watts out. 2880 electrical watts out*1.5=4320 machanical watts, or 5.8HP in... minimum.
This is basic physics... ALL energy can only be converted from one form to another, with all of it's associated losses.
jeffchilcott
Posted: May 18, 2006 at 2:09 PM / IP Logged
I guess I just didnt nitice any horsepower loss because of the motor work I did on our latest CRX.
Added the GM large case Alt   300 amp Irragi   But also added
1988 honda CRX factory 83WHP   from dyno testing
D15B2 lower end. Rebuilt with new rods and pistons. rings ect ect
d16y8 SOHC VTEC head, Mild Port and polish job, crower stage 2 cam with titinimum springs and retainers.
DC Sports full motor back 2.5 in exhaust
Edlebrock intake manifold, accord throttle body (18MM bigger)
AEM V2 cold air intake
PM6 ecu reprogramed for mid range power output for normal driving.
192WHP after about $2300 worth of goodies into the motor, I still have some more work to do there, but I need to start focusing on the audio system, this is supposed to be a SPL vehicle!   haha
2007 World Record
DYohn
Moderator - Posts: 10,741
Posted: May 18, 2006 at 5:38 PM / IP Logged
It's called parasitic losses.  Anything operating while your vehicle is running whether it is electrical like a stereo system or mechanical like your A/C compressor use energy from the engine to operate, which means they require some of the engine's horsepower and also they cause your engine to use more fuel.  Like haemphyst said, you can't got something from nothing.
zhalverson
Copper - Posts: 180
Posted: May 18, 2006 at 7:04 PM / IP Logged
Alright thanks.  That's kind of what I expected but I had no idea on the efficiency of an alternator.  Kind of interesting.  If you think about it the power losses from the alternator draw and the added weight of the sub, box, amps, speakers, damping, etc. there is going to be considerable performance losses,.  I've never really thought about it, and I doubt many people do.
xtremej
Gold - Posts: 1,440
Posted: May 19, 2006 at 8:13 AM / IP Logged
Its amazing how many people don't belive how much these enclosures/amps etc..weigh alone.  I have an install coming in next week to fit 4 12's in the trunk of a grand prix, when its done I guarantee it will be sagging. Maybe I'll post some pics if I get time and figure out how to shrink them.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
