what size capacitor?
stormraider04
Copper - Posts: 91
Posted: May 19, 2006 at 8:32 PM / IP Logged
i will be getting a system soon and i wanted to know what size capacitor i should get. i will have 1400 watts. my friend says i should get a 20 farad cap. i've heard that you only need 1 farad per 1000 watts. is that true? if going off of that should i only need 2 farad cap? one other question. will a cap keep my system running smoothly or should i upgrade my alternator? either bigger alternator or both bigger alternator and a cap? any help would be great thanks.
killer sonata
Silver - Posts: 718
Posted: May 19, 2006 at 10:05 PM / IP Logged
If you upgrade you alternator properly you shouldnt even need a cap. If anything you should get a second battery along with the alternator upgrade - one for the stereo and one for the car itself.
mobilesndfx
Copper - Posts: 49
Posted: May 20, 2006 at 5:10 AM / IP Logged
You only need a second battery if your going to listen to your system with the car off. Otherwise having multiple batteries wont benefit you. HO alternators can be very expensive, but with 1400 watts, you really need one.
jlord16
Silver - Posts: 322
Posted: May 20, 2006 at 7:50 AM / IP Logged
caps do crap all, get a HO alt, best value for money when ur dealing with large power requirments
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
stevdart
Platinum - Posts: 5,816
Posted: May 20, 2006 at 8:50 AM / IP Logged
And depending upon what that output rating really means, you may not need an upgraded alt either.  Initially, spend your money on upgrading the wiring with extreme detail (see the Big 3 sticky).  Install sound damping with equal detail.  After the install is complete you will know if an alt upgrade is necessary.  And also, if you have an older car with a 3- or 4-year old battery in it, replace the battery right from the start.
Aruman
Silver - Posts: 363
Posted: May 20, 2006 at 8:52 AM / IP Logged
do a search on this forum about capacitors, and read this
it will help you understand more about caps.
Shaking The Neighborhood
stormraider04
Copper - Posts: 91
Posted: May 20, 2006 at 8:36 PM / IP Logged
if i get a bigger alternator what is a good size to go to?
Drewt
Copper - Posts: 183
Posted: May 20, 2006 at 11:44 PM / IP Logged
Basically the biggest one you can afford. Another way - figure out how many amps your alternator puts out now and then add the amps that your amplifier pulls (look for the fuses on the amp if there are any), and add in how many amps you plan to use for an upgrade later, if you can afford it.
Example
Your car puts out 60 amps now
Your amplifier has two 30 amp fuses (60 amps)
You're thinking of adding a 4 channel amplifier in the near future that pulls 40 amps
so:
60+60+40=160
look for a 160 amp alternator, get it if you can, if not, get the largest you can afford.
stormraider04
Copper - Posts: 91
Posted: May 21, 2006 at 12:07 AM / IP Logged
is there a certain brand that is better or worse? any good places to get them from?
aznboi3644
Gold - Posts: 2,600
Posted: May 21, 2006 at 1:47 PM / IP Logged
drewt don't forget what the cars electronics already draw. ex. headlights draw about 30 amps. plus the heater and other things. so make sure to add those to the total
Page of 3
