power wire guage?
spazc
Posted: June 22, 2006 at 10:27 AM / IP Logged
thanks in advance to all of those who help me with this.
ok so here is the question: i have a kenwood 2 channel amp running on a 4 guage kit, it has 2 30 amp fuses and runs at 340 watts rms, i am wanting to add an 4 channel amp for my speakers. will i need to upgrade to 2 or 0 guage wire or can i just add a distribution block in for the power and ground terminals?
thanks again for your help
- Chris
you can't fix stupid
spazc
Posted: June 22, 2006 at 10:29 AM / IP Logged
just noticed an unclear part of my previous post, the 2 30 amp fuses are for the amp not the wire kit
Aruman
Silver - Posts: 363
Posted: June 22, 2006 at 10:38 AM / IP Logged
what 4 channel amp are you planning to add?
did you already check this?
Shaking The Neighborhood
haemphyst
Platinum - Posts: 5,059
Posted: June 22, 2006 at 10:49 AM / IP Logged
The 4 gauge will be fine... 4 gauge is rated to 150A, and unless you are adding a HUGE 4 channel amp - something that pulls 90A, you're gonna be well within the safe operating range of #4...
spazc
Posted: June 22, 2006 at 10:56 AM / IP Logged
well honestly im not sure of what amp ill be getting. it will most likely run some where around 40-50 watts rms per channel. ive been looking at sony, alpine and pioneer amps. ill be getting a new car soon and was lookin to see if i needed to upgrade or salvage my old kit.
rumtech
Member - Posts: 16
Posted: June 22, 2006 at 12:04 PM / IP Logged
the first question is how long is the power cable form the battery to the amp
second how many amps does the 4 channel that u are looking to add need?
spazc
Posted: June 22, 2006 at 12:23 PM / IP Logged
well the new car ill be getting is a 2000 civic coupe, so id guess the distance would be between 15 and 18 feet tops. as for the ampage the amplifier will pull i dont know, my sub amp has 2 30amp fuses and its runnin at 340 watts rms bridged so i take a guess that a 50 watt rms 4 channel amp would pull between 20 and 35 amps.
rumtech
Member - Posts: 16
Posted: June 23, 2006 at 3:06 PM / IP Logged
the maximum distance that 4 gauge wire could carry 80-95 amps is 10 ft, so i would suggest 2 gauge.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
