Radio Frequency Interference
Stealthimage
Member - Posts: 8
Posted: June 27, 2006 at 10:16 AM / IP Logged
What would be the main reasons why there is more radio frequency interference when I turn my sub amplifier on?  I know that where I live there is bad reception to begin with, but when I turn my sub on it gets worse.  I verified this with a station that doesn't come in too well to begin with.  It's not a really big deal, but I would like to know what might cause this from an installation standpoint.
ld11
Posted: June 27, 2006 at 11:38 AM / IP Logged
I'll take a stab at this. Amplifiers for subwoofers are generally class D switching amplifiers. It uses pulse width modulation to create an amplified signal which passes through a low-pass filter to get a smoother signal.
The quick on-off switching creates excess high-frequency radio interference which may be affecting your radio.
Stealthimage
Member - Posts: 8
Posted: June 27, 2006 at 2:43 PM / IP Logged
So what might be the cure for this, taking the switch off of the amp and wiring it with my four channel?
