amps for my subs
bigjosh1
Posted: June 28, 2006 at 8:03 AM / IP Logged
hay all
plz im hopeless on finding the right amp i need, i have 2 12" TS - W306C,
1000 watt max handling, 400 watt nominal power handling
pleased gve advice on the amp i need
aznboi3644
Gold - Posts: 2,600
Posted: June 28, 2006 at 8:07 AM / IP Logged
What is your price range?
bigjosh1
Posted: June 28, 2006 at 8:10 AM / IP Logged
300 - 400 aussie dollars
forbidden
Platinum - Posts: 5,354
Posted: June 28, 2006 at 11:18 AM / IP Logged
If the subs are svc 4 ohm, the Scosche HD5001 amp is built like a tank, dissipates heat very well and makes 800w  rms into 2 ohm mono. It retails for about the $500.00 CDN mark.
http://www.scosche.com/efx.aspx?CategoryID=50&ItemID=HD5001
Another good amp to consider, although less on the power side and again rated to 2 ohms is the Concept CA525M. It retails around the $400.00 CDN mark and makes 525w rms into 2 ohm mono.
http://www.conceptconcept.com/proddetail.asp?ID=70&ProductLine=Amplifier
