car that need the factory head unit
audio Xclusive
Member - Posts: 30
Posted: May 14, 2002 at 12:27 AM / IP Logged
I've been told that their are certain cars that need the factory radio to function correctly.
Some honda civic, new cavilers,
I know one guy that placed his factory radio under his spear tire connected so he could put an aftermarket in the dash.
does anyone have a list of problem cars what the problems are and the best way to get around the problems.
another Xclusive installation
Big Dog
Gold - Posts: 1,265
Posted: May 14, 2002 at 9:48 AM / IP Logged
Hey Xclusive,
There are more and more that communicate with the BCM thru databuss.  For example ; 02 Envoy, 01 Gr Am, 01 Sunfire, 01 Alero, 01 Impala, 01 Malibu, 01 MonteCarlo, 02 Trailblazer.  The removal of the factory radio in these vehicles will result in the loss of the door chimes and other vehicle systems that rely on the OEM radio. There is also the possibilty of the airbags inadvertently being disabled.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Platinum - Posts: 12,488
Posted: May 14, 2002 at 6:14 PM / IP Logged
1998 + Honda Accord, CR-V and odyssey ( Canadian spec'd ) have a ground loop that needs to be connected through the factory radio or else the factory alarm/ keyless entry module does not work at all. This is a simple bypass though, no relocation of the OEM deck, just a single wire.
OmarZ
Member - Posts: 8
Posted: December 30, 2002 at 9:24 PM / IP Logged
Could someone be specific on the installation of a head unit into a 2001 Malibu,  i have the relocation harness, but where do I actually put the factory unit.  I figure somewhere in the trunk, but mounted somewhere?  All i can picture in my head is a deck laying in the trunk. lol (sort of)
Anyway, any suggestions would be great.  And is there any special wiring tips besides just wiring the relocation harness up?
Posted: January 01, 2003 at 10:44 AM / IP Logged
That's about it !! If you wanted to you could tie it up in the corner under the deck in the rear.
