VW, Memphis Amp getting hot
davedyer79
Copper - Posts: 178
Posted: July 10, 2006 at 9:24 AM / IP Logged
Hello, I installed a Panasonic head unit, Memphis amp (500D) and a Memphis PR12 DVC in a Memphis slot ported box in a 2003 VW Passat this weekend.  I just looped the coils together and into the left side of the amp.  For some reason I keep blowing subs (frying the coil, therefore when  you push on the speaker it doesn't move) and the amp stays REALLY hot.  I have installed numerous of these setups in cars and have never had this problem.  I replaced the amp twice and the sub 3 times.  I have tested all the connections repeatedly with a DMM, all meter correctly.  Has anyone ever had this problem with a Volkswagon, or is it me.  The ground is only 2 ft long, all power leads are 8 guage, 50 amp fused.  Advice would be appreciated.  Thanks, David
davedyer79
aznboi3644
Gold - Posts: 2,600
Posted: July 10, 2006 at 6:26 PM / IP Logged
Is your gain set correctly???
12vdeej
Member - Posts: 26
Posted: July 10, 2006 at 7:00 PM / IP Logged
As far as im aware most/all amps these days have DC protection, but the situation you are describing sounds just like that to me. Any DC offset present within the audio signal will cause the voice coils to heat up rather than producing noise, leading to failure as you described. It would also cause the amps to get hot. If you can, test the output of the head unit to see if there is any DC voltage present within the output signal. Seeing as this is the only component that didnt get replaced it could have been the culprit. Also double check that you arent somehow short circuiting the output of the amp as this would lead to the same overheating problem. The suggestions i have made are unlikely situations, but are the only ones i can think of! As aznboi3644 suggested, turning the volume up too much will fry your sub, but thats so obvious its almost insulting !VW, Memphis Amp getting hot -- posted image.
aznboi3644
Gold - Posts: 2,600
Posted: July 10, 2006 at 8:04 PM / IP Logged
Lol...well some people overlook the most obvious.
davedyer79
Copper - Posts: 178
Posted: July 11, 2006 at 8:26 AM / IP Logged
Well, I checked all the connections again, 13.8volts at 12V, good ground, no junk at RCA and no DC/AC going to the subwoofer.  I wonder if I have the connection to the amp correct.  The Memphis 500D is a mono-block amp.  I just daisy chained the two coils together to a 2 ohm load (DVC 4 ohm) and tied them directly into one channel of the amp.  Should I have used the outside connections + and - ( I guess bridged mode, but you cannot "bridge" per say this amp).  Could a ohmage issue cause this amp to overheat??  The Memphis tech said I am pushing too much to the subwoofer, therefore blowing it.  I guess I can understand that.  I have pushed more wattage than this to these subs before with no problems.  But that doesn't explain why the amp is getting so hot.  Thanks so far for the suggestions.
davedyer79
aznboi3644
Gold - Posts: 2,600
Posted: July 11, 2006 at 11:08 AM / IP Logged
You cannot bridge the amp...It only has two sets for easy wiring.
I looked at the site for those subs and the rms rating is 250 watts rms correct...Well at 2 ohms your pushing 500 rms to that sub...Have you not realized that is more power than the sub can handle?
