Pioneer Shallow Subs
geoffl
Member - Posts: 8
Posted: July 14, 2006 at 6:22 PM / IP Logged
Has anyone heard the Pioneer Shallow Subs? I want to get the 12" Model #TS-SW3041D but I am worried about the sound. Has anyone had any experience with them? Pros/Cons? Please let me know. Thanks.
Pioneer Shallow Subs -- posted image.
Geoff
geoffl
Member - Posts: 8
Posted: July 14, 2006 at 7:33 PM / IP Logged
I was thinkin about putting them behind the back seat of a 2005 F-250 since there isn't much room at all behind it.
Does anyone else have an opinion?
Geoff
jvillefinest
Copper - Posts: 255
Posted: July 15, 2006 at 5:54 PM / IP Logged
heard one under the seat of a chevy avalanche. and like was said before, for something that nothing else can fit in...it sounded alright. behind the seats of regular cab trucks we have done some 10s behind the seat depending on how tall you are. We have done from 2 10w1 up to 2 10w3v2. So before going for the flats make sure you have NOOOO room, because if you have 5-6 inchs or so you can get something better.
2007 Acura TSX
SQ setup in the works
KarTuneMan
Platinum - Posts: 7,056
Posted: July 15, 2006 at 7:49 PM / IP Logged
These subs are a solution to a problem. They are not REAL musical, nor do they BOOM. But like I said, they ARE a solution to the "no space" problem, plagueing some vehicles. Build the boxes AS BIG AS YOU HAVE SPACE FOR.
KarTuneMan
Ravendarat
Platinum - Posts: 2,806
Posted: July 15, 2006 at 8:09 PM / IP Logged
I just installed one of these in a 2001 ford F-150 in a standard truck box running off 200 watts rms and it sounded good for what it is. I mean he wont win a competition or anything but it does its job and fills in the bottom end nicely
soultinter
Copper - Posts: 170
Posted: July 17, 2006 at 11:49 AM / IP Logged
just did 2 of the pioneer shallow 12's in a 99 chvey x cab w the audio enhancers custom enclosure and a rockford P600.1bd and it sounded quite good, approx .8cu per sub. firing up
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
