idmax d2 v3 powered by zapco ref 1000.2
fun-stf
Posted: July 18, 2006 at 10:59 AM / IP Logged
if anyone would like to tell me the best way to wire these 2 .i would be verry happy.
sub is duel 2 ohm \
amp is 2 ch    bridgedch 4 ohm stable
stereo    2 ohm
thank you very much
eclipse 3423,image dynamics cd-2 horns image dynamics \ cxs6.2 mid bass ,cxs5.2 mids/tweets ,id-max v2d3 zapco ref 1000.2 \ref 750.2 \ref360.4,zapco sp7,,symbilink cables, audio control
fun-stf
Posted: July 19, 2006 at 10:15 PM / IP Logged
the best way to wire these ?if i ran one voice coil of the idmax v2. to the left channel of the ref 1000.2 and the other voice coil to the right.would this work ?my enclosure is almost done , so i will be installing this or another sub .depending on the reply's i get .              thanx 2all
geepherder
Platinum - Posts: 3,668
Posted: July 20, 2006 at 6:08 AM / IP Logged
Electrically it makes no difference at all whether you connect it 2 ohm stereo or 4 ohm mono.  You could do it the way you described or connect the voice coils in series and bridge the amp.
fun-stf
Posted: July 23, 2006 at 1:56 AM / IP Logged
thanx for the info geepher der . i thought i might get more out of the amp if i ran it in 2 ohm stereo ? is what you are telling me , that the output would be the same or close to if i ran it 2 ohm stereo or 4 ohm mono ?
aznboi3644
Gold - Posts: 2,600
Posted: July 23, 2006 at 10:57 AM / IP Logged
Yes...output will be the same with running your amp 2 ohms stereo or 4 ohms bridged...no difference...besides bridged the amp will show less wires.
fun-stf
Posted: July 23, 2006 at 12:19 PM / IP Logged
that is great ! thank you ....
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
