which sub should i pick
ralphpylayanum1
Member - Posts: 12
Posted: July 19, 2006 at 12:32 AM / IP Logged
13.5 jl w7s   or 12 inch strokers the old ones whith the yellow piston area in the middle i have a amp which give out 3000 rms at 2 omhs 1800 at 4 ohm its the 3000.1 massive these subs are going in a bandpass ported into my 97 nissan altima or the ul's critical mass subs 2500 rms 5000 peak which is a better over all sub the will hit hard low and give me lots of preassure
rafael rodriguez
forbidden
Platinum - Posts: 5,354
Posted: July 19, 2006 at 1:58 AM / IP Logged
Have a real good hard long look at the DD subs, you can't go wrong with them for a application like the one you are listing.
aznboi3644
Gold - Posts: 2,600
Posted: July 19, 2006 at 2:14 AM / IP Logged
Is your charging system up to the task of running that amp???
Just wondering.
jeffchilcott
Platinum - Posts: 2,483
Posted: July 19, 2006 at 7:12 AM / IP Logged
The charging system is not up to par,   thats why he has another post about it...I have recomended a very very large alternator.
I would follow buy saying Kicker L7's or DD.   Could also look into RE
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
ralphpylayanum1
Member - Posts: 12
Posted: July 19, 2006 at 8:28 AM / IP Logged
i hacve l7's as we speak in a bandpass they sound real decent im scared of blowing into pieces
rafael rodriguez
jeffchilcott
Posted: July 19, 2006 at 9:32 AM / IP Logged
Ditch the bandpass....build a decent ported box and run 4 l7's and they will last all day.   The new 06 L7's (A Pair) will take 3000 daily......Even the old L7 12's will take a kx1200.1 per sub for daily use if set up correctly, and kept from clipping
2007 World Record
ralphpylayanum1
Member - Posts: 12
Posted: July 19, 2006 at 1:31 PM / IP Logged
well i have 04's and 2 06 except one blown but 1 if i ditch the bandpass i wont get my bass in the car and 4 l7's will be alot of work to fit i already have dynamated the whole car and when i had my subzone more ratlle than music lol so i made bandpass and i loved it so wat do u think should i get jlw7's or mmats jugs im gettin good deals on them
rafael rodriguez
mtmas8
Member - Posts: 17
Posted: July 19, 2006 at 1:46 PM / IP Logged
i dno about you but i have 2 13w7's in my car just sealed and it barely fits in the trunk i dont know how you would do 2 13w7's in a ported/bandpass box. also what kind of amp is your 3000 watt? because 13w7's run at a 1.5 ohm so you shuold check if ur amp is stable at that and how effecient the amp is. also you may want to think about putting in 2 or 3 more batteries ive heard 1 battery per 1000 watts. i currently am using 2 batteries and my main starter battery running under a 240 amp alternator and it seems to be working fine. i am running 2450 total watts right now.
Alpine D310 HeadUnit
Alpine PHX-H701 Signal Processor
(2) JL 13W7 Subs
(2) JL 1000/1 Amps
