Boston Acoustics SL60 crossover wiring
azrapse
Member - Posts: 29
Posted: July 27, 2006 at 6:21 PM / IP Logged
Im confused on how to wire them, im a rookie so I dont know much about crossovers, if you look at the manual http://www.bostonacoustics.com/Manuals/SL60Man.pdf     im using the single input wiring because I have a 4 channel amp and im using 2 channels for the 6x9 in the back. So all I need is 2 channels for the comps right?  If you look at the bottom of the manual on (D) wire connections it has an exclamation mark and it says single input what am I supposed to do?  When I turn my system on I cant hear the comp's woofers only the tweeters.      PLZ HELP
azrapse
Member - Posts: 29
Posted: July 27, 2006 at 7:34 PM / IP Logged
Never mind, I Figured it out, sorry for the post
