Amp, sub?
beema
Posted: July 30, 2006 at 11:44 AM / IP Logged
Hey guys, What would you suggest to power 2 of these? Thanks
http://www.crutchfield.com/S-eFuSc2KBFsj/cgi-bin/ProdView.asp?wm=fp&I=500SWR1242
cloak559
Copper - Posts: 215
Posted: July 30, 2006 at 2:08 PM / IP Logged
How much are you looking to spend?  And would you be willing to swap for the Dual 2ohm Type-R subs?
'89 Mercedes-Benz 300E
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...
killer sonata
Silver - Posts: 718
Posted: July 30, 2006 at 2:24 PM / IP Logged
alpine pdx 1000.1
"People with mullets live 40% longer"   - Ricky Bobby
beema
Posted: July 31, 2006 at 9:38 AM / IP Logged
thanks killer sonata,  And what do you mean swap cloak559? And money is not a factor because you get what you pay for. I also forgot to add I am keeping it all alpine. But I think I will go with what killer sonata Said. Thanks
aznboi3644
Gold - Posts: 2,600
Posted: July 31, 2006 at 10:32 AM / IP Logged
Cloak means this because with your two dual 4 ohm coils only wiring options you have are 1 ohm and 4 ohm...using all coils.
You can use one coil on each and get a 2 ohm load but that would be pointless...somewhat.
If you switched to the dual 2s you can load a mono amp at 2 ohms wiring the subs in series/parallel.
beema
Posted: July 31, 2006 at 1:38 PM / IP Logged
Well, what would sound, and work the best? If I switched to the dual 2s and load a mono amp at 2 ohms wiring the subs in series/parallel
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
