2006 Toyota Camry
delandy77
Posted: August 01, 2006 at 1:29 AM / IP Logged
I need a head unit wiring diagram for a 2006 Toyota Camry SE w/ JBL system.  Thanks!
kgerry
Platinum - Posts: 3,455
Posted: August 01, 2006 at 12:41 PM / IP Logged
RADIO HARNESS
+12V DC Battery(Constant)Switched AccessoryGround Remote Turn On(output) Illumination Mute Steering Wheel Control Wire Left Front + Right Front + Left Rear + Right Rear +
Wire FunctionColorNoteFuse #SizeLocation
Blue / YELLOW  Rad 1 20 Amp Junction box behind left side of dash
Gray  Rad 2 10 Amp Junction box behind left side of dash
Brown Signal ground is white
Pink/blue
Green & WHITE/ green
Brown
Yellow or blue Also black or red; & orange or black
Blue Line level output
Black Line level output
Yellow Line level output
Green Line level output
2006 Toyota Camry -- posted image. AMPLIFIER OUTPUTS
12V DC BatteryRemote Turn On (input) Left Front Tweeter + Left Front Tweeter - Right Front Tweeter + Right Front Tweeter - Left Rear Mid + Left Rear Mid - Right Rear Mid + Right Rear Mid -
Pink/blue
Pink To pin 1 of tweeter, and out of pin 3 to the left front door speaker.
Violet To pin 2 of tweeter, and out of pin 4 to the left front door speaker.
Light green To pin 1 of tweeter, and out of pin 3 to the right front door speaker.
Blue To pin 2 of tweeter, and out of pin 4 to the right front door speaker.
Black
Yellow
Red
White
2006 Toyota Camry -- posted image. AT SPEAKERS
Left Front Mid + Left Front Mid - Right Front Mid + Right Front Mid -
Pink
Violet
Light green
Blue
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
