Suggestions on a good amp, at low price?
hemanjoyman
Copper - Posts: 77
Posted: August 25, 2006 at 6:23 PM / IP Logged
I'm looking for a four channel amplifier to power two infinity 6"x9" 692.5i, and an infinity component set 60.7cs.
I want the amp to actually put out it's rated power, at least 75 watts RMS.
But I want a better than entry level amp, I would prefer something that is not in the JL Audio 300/4 range, it's too expensive.
Also, most amps are rated at 14.4V, but there is no way my charging system can put out that much voltage, at most, I think It can put out is 13.5, maybe a little less.
Thanks.
Any suggestions.
KarTuneMan
Platinum - Posts: 7,056
Posted: August 25, 2006 at 8:19 PM / IP Logged
take a look at www.planetaudiousa.com
The ZR300.4   4x75 @ 4ohm  $269.00
hemanjoyman
Copper - Posts: 77
Posted: August 25, 2006 at 9:14 PM / IP Logged
Is the ZR300.4 a good amp??? I had never heard of this brand until now. I found this amp on ebay for $85. The price seems to low to be true for a quality amp.
Also, the infinity reference amp doesn't state it's RMS power at 2 ohms, which is what the 60.7cs component set are. It just says it's 164 watts dynamic power, whatever that is.
hemanjoyman
Copper - Posts: 77
Posted: August 25, 2006 at 9:18 PM / IP Logged
Sorry, that's $95 dollars, not $85, my mistake. I also forgot to mention that the ZR300.4 doesn't mention RMS power at 2 ohms either; it says max power is 150W X 4.
aznboi3644
Gold - Posts: 2,600
Posted: August 26, 2006 at 1:39 AM / IP Logged
Planet Audio is a good company...I've seen some pretty loud systems with this brand...amps are better than entry level
