PA or Kicker CVR 12
rehoredneck11
Member - Posts: 9
Posted: September 18, 2006 at 12:30 AM / IP Logged
I have a GMC single cab truck and i was wondering what wud be better ....the new power acoustik shallow sub or the kicker CVR?What would be better for my ride? I have a class d 1000 for the subs
stevdart
Platinum - Posts: 5,816
Posted: September 18, 2006 at 5:35 AM / IP Logged
Reputation of build quality will put the Kicker over the Power Acoustik.  You should get around and listen to some setups with these (and other) subs before you commit.
snoracer98
Member - Posts: 15
Posted: September 18, 2006 at 2:04 PM / IP Logged
i would go with the PA kws12 or kws10, it is the exact same sub as the kicker comp cvr. i have 2 12inch kicker cvrs and orderd a PA one for a friend who didnt want to spend more money.. put the subs side by side there is not a difference between the 2 subs other then the print on the cones.
aznboi3644
Gold - Posts: 2,600
Posted: September 18, 2006 at 3:27 PM / IP Logged
Lol...highly doubt they are exactly the same...Power Acoustic may have tried to imitate the look...but the sound i doubt is anything compared to the Kicker
snoracer98
Member - Posts: 15
Posted: September 18, 2006 at 4:05 PM / IP Logged
now i didnt rip one apart and check the coils or spyder to make sure theres not a single differnce, but i have listened to them, even swaped my kicker with it to test it out in my box, i would bet that the same exact company makes that sub for kicker and PA, one is less then half the cost, but ever stich and spot of gule are exactly the same.
nstaln
Member - Posts: 9
Posted: September 18, 2006 at 8:22 PM / IP Logged
The  ultimate shallow mount driver. 15mm xmax..about the same as an Alpine Type R...except much more musical! I don't know what your budget is but TC Sounds makes this in a 10 and a 12.
PA or Kicker CVR 12 -- posted image.PA or Kicker CVR 12 -- posted image.
rehoredneck11
Member - Posts: 9
Posted: September 18, 2006 at 10:29 PM / IP Logged
Here are the pictures of the power acoustik .... its almost the same as the tc ...what u think ? today i went and listened to some CVR's at circuit city and not what i expected but L5 10's sounded goodPA or Kicker CVR 12 -- posted image.
nstaln
Member - Posts: 9
Posted: September 19, 2006 at 10:16 PM / IP Logged
Howdy  Redneck,
I compared the two subs and this is what I found:
PA: ceramic(standard material) magnet , TC neodymium(extremely powerful) magnet
PA: 2inch aluminium coil, TC 2inch aluminium or copper coil
PA:400rms 800peak, TC  350rms 800peak
PA: aluminium cone, TC  carbon fiber nomex piston(same as PPI proclass)
PA: 8mm xmax(one way), TC  15mm xmax(one way) almost twice the excursion
PA:  foam surround, TC rubber surround
PA: "jack of all trades" company, TC only builds subwoofers(20+ years of OEM manufacturing subs for Eclispe, MTX, Audiomobile, Digital Designs, Crystal Mobilesound, Soundsplinter,...)
PA: $110 roughly, TC $250 roughly
I'm all about SQ with authority, for me the choice is clear, TC has better materials, much larger displacement, and has audiophile sound quality. But it does come at a price $$$$
stevdart
Posted: September 19, 2006 at 10:27 PM / IP Logged
Uhhh....
What was the original question again?
nstaln
Member - Posts: 9
Posted: September 19, 2006 at 10:53 PM / IP Logged
Uhhh...
Subwoofer options.
