- from + on speakers?
jahnkematthew
Member - Posts: 19
Posted: September 22, 2006 at 2:04 AM / IP Logged
intalling new speakers in my 92 honda accord and the wires are weird colors. how to i tell what is (+) and what is (-) if the colors of the wires are blue and green (other speaker wires are different colors too)? the one thing all the wires in the car have in commen is that the two wires have 1 white strip through it and the other has yellow stripe.  which is (+) and which is (-)?
thanks
matt
caraudio904
Copper - Posts: 115
Posted: September 22, 2006 at 2:06 AM / IP Logged
Did you cut off the factory wire harness?
Southern Stylez
Jacksonville, FL 32218
jahnkematthew
Member - Posts: 19
Posted: September 22, 2006 at 2:07 AM / IP Logged
yeah
caraudio904
Copper - Posts: 115
Posted: September 22, 2006 at 2:09 AM / IP Logged
Big mistake! If you still have it you can use it to tell what is what.
Southern Stylez
jahnkematthew
Member - Posts: 19
Posted: September 22, 2006 at 2:11 AM / IP Logged
i still have it....but how does that tell me....it doesn't say anyhting on it!
caraudio904
Copper - Posts: 115
Posted: September 22, 2006 at 2:15 AM / IP Logged
Well the way is that you were supose to purchase the after market plug (about 10 bucks) an just connect those wires to the cd player an then plug it into the factory plug, your done. the after market an the cd player use the same colors kinda make it fool proof. little chance of error an just neater an quicker
Southern Stylez
jahnkematthew
Member - Posts: 19
Posted: September 22, 2006 at 2:25 AM / IP Logged
no no, i did that....im not working with the deck....just with the speaker and the speaker wire (that worked with the new deck installed) now the harness the plugs directly into the speaker has two wires...and now ones neg and ones pos...
caraudio904
Copper - Posts: 115
Posted: September 22, 2006 at 2:26 AM / IP Logged
The great things about wires an harnesses is that they can always be reconnected or extened. Pretty much. Its fixable.
https://installdr.com/InstallDocs/Honda/PDF/466033.pdf
Cheat sheet for ya.
Southern Stylez
caraudio904
Copper - Posts: 115
Posted: September 22, 2006 at 2:27 AM / IP Logged
Oh okay i got you now. look on page 7/8 of that site i gave you. you will have your answer
Southern Stylez
jahnkematthew
Member - Posts: 19
Posted: September 22, 2006 at 3:04 AM / IP Logged
ahh man perfect!! thanks alot, thats awesome..
thanks
matt
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
