Problems after battery terminal
quick94gt
Member - Posts: 27
Posted: October 22, 2006 at 7:30 PM / IP Logged
 I have a 2002 Mustang Gt that im installing a system in, i just installed the Knukonceptz positive battery terminal, ran my 4 guage wire and rca cables, i crimped the battery cable to a ring connector, and installed it on the battery, now when im driving the guages act up and the stereo turns off, and on top of that the car whants to shut off  WHILE driving...Did i do something wrong??? I didnt use a crimper, i smashed it whith a vise-grip, should i solder it to the ring terminal??? how do you do this??? what did i do wrong??? the car was 100% fine before the install.
coppellstereo
Silver - Posts: 785
Posted: October 22, 2006 at 7:40 PM / IP Logged
is the connection 100% secure? any play in the tightness of the terminal could affect this. Did you change any other wiring?
silverado42000
Copper - Posts: 65
Posted: October 22, 2006 at 7:55 PM / IP Logged
if its messing with the gauges and making the car want to turn of it sounds like your batt is grounding out, might want to check everything out and make sure you did everything right
Problems after battery terminal -- posted image.
quick94gt
Member - Posts: 27
Posted: October 22, 2006 at 7:57 PM / IP Logged
  I didn't change any other wiring, just ran the power wire to the trunk, the factory uses two wires a 4 guage it seems and a seperate 8 guage which is i think the altenatoe wire because it seems to go to the fuse box, so i used two seperate ring terminals because i didn't have a big enough one for both wires, if there's any play in the wires will it cause this??? like i said i had to use a vise-grip to crimp them...should i Solder them to the ring terminals???
quick94gt
Member - Posts: 27
Posted: October 22, 2006 at 7:59 PM / IP Logged
  The power wire is hooked up to the terminal but i have not put an amp in the car yet, I sealed off the end of the power wire with duct tape...would this make the battery ground out since it's hooked up to the battery terminal???
killer sonata
Silver - Posts: 718
Posted: October 22, 2006 at 8:46 PM / IP Logged
it may have reset your ECU
Saturday, July 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
