i want to run 2 amps for 2 different jobs
wildchildbmx6
Member - Posts: 39
Posted: November 02, 2006 at 8:30 PM / IP Logged
i want to run 1 for my subs and the other for my speakers. how do i do that without using a Y adaptor. do i need a headunit that can handle the different channels? want to be able to control the subs and speakers seperatly. please guide me in the right direction
coppellstereo
Silver - Posts: 785
Posted: November 02, 2006 at 8:43 PM / IP Logged
if you are using your stock head unit, you will nead a 'line output converter' for each pair of inputs (channels).
or you will need an amp that can handle 'high level inputs'
or you will need a head unit with subwoofer and speaker RCA outputs
coppellstereo
Silver - Posts: 785
who is going to install this for you?
wildchildbmx6
Member - Posts: 39
Posted: November 02, 2006 at 8:50 PM / IP Logged
im installing it all. i have a pioneer headunit and im not sure if i have two rca outputs havent looked. i know how to install, ive just nevver installed two amps to do two different things
silverado42000
Copper - Posts: 65
Posted: November 02, 2006 at 10:04 PM / IP Logged
if its a newer HU then it most likly has both sub and rear or front outputs, take a look then if im right then just use an rca cable for the subs. then another for the speakers. good luck, hope this helps
i want to run 2 amps for 2 different jobs -- posted image.
rabreedlove
Member - Posts: 13
Posted: November 03, 2006 at 5:22 AM / IP Logged
Yea!  Maybe I can actually contribute something for a change...
To control the speakers/subs separately from the head unit, you'll nead a HU with 3 sets of pre-amp outputs.  If you already have a HU with 2 sets of pre-amp outputs, then get an amplifier (if you haven't bought them already) that has a low-level RCA passthrough to send the signal to your sub amp.
You'd send the 4-channel signal from the head unit to the speaker amp with 2 RCA cables and send an RCA cable from the speaker amp to the sub amp.
However, doing this won't give you control over the sub/speakers independently, although you can compensate for it.  In my case, I kept my factory in-dash changer and passed the signal to the sub amp through from the speaker amp.  My Rockford Fosgate Punch sub amp has a bass controller knob that I installed under the driver's seat that I can use to quickly increase the sub output.
Hope this helps...
