2000 GMC yukon xl
904sorock
Posted: November 08, 2006 at 2:26 AM / IP Logged
I will be installing aftermarket amplifiers to my  non Bose factory system. Does anybody know if i need line level converters and where i can tap into wires .  Color code would be helpful. Door speakers will also be replaced. Factory stereo will not be changed.  Also , for ampifier remote turn on lead  should i get it off a regular ignition wire. thanks
Salmen
jason quarters
Member - Posts: 18
Posted: November 18, 2006 at 6:14 PM / IP Logged
Radio Ground
Radio Ignition
Radio Illumination
Factory Amp Turn-on
Power Antenna
LF Speaker +/-
RF Speaker +/-
LR Speaker +/-
RR Speaker +/-
its true!
mike12volt
Copper - Posts: 98
Posted: November 19, 2006 at 4:12 PM / IP Logged
Some amps have speaker line inputs. In that case, you may not need an rca line converter.
