900w rms at 1ohm amp, 500w subs
kristofsky4
Posted: November 21, 2006 at 1:20 AM / IP Logged
i am buying an amp and two 12 inch subs,  the rating on the amp says that it is 1 ohm stable and produces 900 w with this load ( produces 500 watts with a 4 ohm impedence), the two subs i was looking to buy are 500w 4 ohm dvc, so if i buy this set up will i love up the subs because i am not giving them enough juice? i was planing on wiring them parallel (if my calculations were right this produces a 1 ohm impedence)  to the mono channell amp... but the amps are each 50 watt under powered........
P.S. is there any draw backs to using a lower impedence ? or things i should look out for as to not short out my amp or something.....?
thanks for answers!
jlord16
Silver - Posts: 322
Posted: November 21, 2006 at 4:28 AM / IP Logged
Mate you wont notice lacking 50watts of power, its not an audiable difference.
If the amp is rated @ 1 ohm it will hadle it not a problem but usually lower impedance means the amps run hotter (but the amp will be ok cuz its rated for 1ohm usage).
The lower the impedance the more distortion and "dirty signals" there will be (generally), through a subs its not a big deal but for SQ or on front speakers it would be.  Seetup sounds fine to me
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
j_darling2007
Copper - Posts: 210
Posted: November 21, 2006 at 8:46 AM / IP Logged
Sounds like it will work to me too.  Just out of curiousity, what kind of subs and amp do you have?
There are 3 kinds of people in the world, those who can count and those who can't
aznboi3644
Gold - Posts: 2,600
Posted: November 21, 2006 at 7:31 PM / IP Logged
Um...let me guess...the amp he has is a Kenwood KAC-9152D and subs are Alpine Type R's???
Am I correct...I think I am on the amp...but subs not for sure
jlord16
Silver - Posts: 322
Posted: November 21, 2006 at 8:56 PM / IP Logged
Was thinking it was the Kenwood KAC-9152D, went looking for 500w mainstream brand subs with 500wrms on a 12", only came up with the Alpine Type R's
Clarion DB36MP
Respone 800w Mono
ALPINE MRP-F250
kristofsky4
Posted: November 21, 2006 at 8:57 PM / IP Logged
aznboi3644 is correct it is the kenwood 9152D amp and alipne type r subs, they look perty good for the price from what i read, and im on a budget,
any opinions on this equipment?
aznboi3644
Gold - Posts: 2,600
Posted: November 22, 2006 at 12:19 AM / IP Logged
I really like the Kenwood amps...and I had a set of those Type R's this past summer...they have a ton of potential and sound real smooth
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
