2007 Dodge Mega Cab
mexi
Copper - Posts: 156
Posted: November 24, 2006 at 9:05 PM / IP Logged
Anyone have the best place to catch the wires for a loc in a new dodge. It does have the infinity system. I tried doing a search but its been a long day so i might of overlooked it. Any info is appreciated. Thank you
mexicang
master5
Silver - Posts: 1,123
Posted: November 25, 2006 at 2:36 AM / IP Logged
I haven't done an 07 yet but on all the other dodges it is easy as pie to catch a rear speaker wire. pull the sill and look under it in the back for the wire. might have to remove a side panel but if it's in a door (I don't know your model) catch it behind the b pillar.you will see it going into the door boot area.
forbidden
Platinum - Posts: 5,354
Posted: November 25, 2006 at 2:02 PM / IP Logged
Nope, in some of the newer Dodges the rear speakers are high passed. Go to the front speaker woofers ideally. They should be able to be found on the inside of the kick panels. I can't recall the wire colors but it should be easy to figure out with a meter.
master5
Posted: November 25, 2006 at 3:49 PM / IP Logged
agreed,  of course you don't want to tap off a high passed speaker to run a sub. If you suspect the rears are high pass go to the front woofer. even better if there is a factory sub but can't say for sure until I find out all the options on the 07's.
I will check some sources to see if I can find a diagram for an 07 w/ infinity and post back.
master5
Posted: November 25, 2006 at 3:54 PM / IP Logged
LF Speaker +/-  dk. grn/yel - dk. grn/lt. blue  +,-  radio harness or amp behind glovebox
RF Speaker +/-  gray / YELLOW - gray/lt. blue   +,-  radio harness or amp behind glovebox
LR Speaker +/-  gray/lt. grn - gray/dk. grn   +,-  radio harness or amp behind glovebox
RR Speaker +/-  dk. grn/lt. grn - dk. grn/gray  +,-  radio harness or amp behind glovebox
This is for an 06..should be the same. Now the amp behind the glovebox is kinda a pain so you would be better off checking if you can find these colors at the kick going into the door boot/jam area and grab them there.
let me know if theres any problems and I will try my best to find an 07 diagram if it's different.
