99/00 Chevy Malibu Radio Issue
bassplayer24_7
Copper - Posts: 40
Posted: November 27, 2006 at 9:09 AM / IP Logged
ok this is for my sisters car. she had some engine work done to the car recently and since then she has had to enter the security code into the radio to get it to work. its the stock radio that came with the car. now she doesnt remeber the code and cant get it to turn on. i'm wondering if there is a way to reset it or do something so it will work. any help will be of assistance, thanks in advance
(2) 12" JL W3V3
(1) 6" JL W0
Phoenix Gold Octane R 8.0:1
Phoenix Gold Octane R 2.0:1
Phoenix Gold Octane R 5.0:4
Clarion Crossover
JVC Head Unit
bassplayer24_7
Copper - Posts: 40
Posted: November 27, 2006 at 9:17 AM / IP Logged
ok, i was just doing some research on here using the nifty search option and found that its the theftlock, all the articles i found (3) had useful info but the links within them about unlocking it didnt work. so i'll continue to research
(2) 12" JL W3V3
(1) 6" JL W0
Clarion Crossover
JVC Head Unit
jvillefinest
Copper - Posts: 255
Posted: November 27, 2006 at 11:05 AM / IP Logged
in the vehicles we have had problems with this in. the number is usually in the glovebox or in the owners manual. check it out.
2007 Acura TSX
SQ setup in the works
dwarren
Posted: November 27, 2006 at 11:54 AM / IP Logged
If the code is not available, you will have to reomve the radio, get the serial number and usually provide the VIN# to the dealership for the code.
geepherder
Platinum - Posts: 3,668
Posted: November 27, 2006 at 12:16 PM / IP Logged
Here's another option as well: http://www.radio-code.com/?gclid=CMKLv97n54gCFR1sWAodnEjqog
sparkie
Platinum - Posts: 2,061
Posted: November 27, 2006 at 12:38 PM / IP Logged
Don't remove the radio and don't try entering codes. If you have entered more than 7 incorrect codes, you must have the car's ignition on for minimum one hour before anything can be done. Take your car to a GM dealer and they can unlock the radio very easily. They can pull a back up code out of the radio and use it to derive a proper unlock code. Have them either tell you the code so you can record it or deactivate the system so it won't lock unless you decide to put in your own code.
sparky
bassplayer24_7
Copper - Posts: 40
Posted: November 27, 2006 at 1:24 PM / IP Logged
thanks guys, i found a couple tutorials by searching google and i'm going to try those along with what you all have reccomended, thanks again
99/00 Chevy Malibu Radio Issue -- posted image.
(2) 12" JL W3V3
(1) 6" JL W0
Clarion Crossover
JVC Head Unit
bassplayer24_7
Copper - Posts: 40
Posted: November 28, 2006 at 11:01 PM / IP Logged
ok, just so you all know, i got it to work and disabled the theftlock, thanks again
(2) 12" JL W3V3
(1) 6" JL W0
Clarion Crossover
JVC Head Unit
