1999 Silverado Switched ignition
bentleyrb
Posted: December 17, 2006 at 6:34 AM / IP Logged
Just purchased a 99 Silverado
and the stock radio wasn't working.
The clock on it worked but wouldn't power up.
I installed a new Pioneer purchasing the
pioneer harness to Gm harness and it didn't power up.
I used a multimeter at the vehicle harness and get
constant 12v at the orange but Nothing at the switched
Yellow wire.
Radio fuse under hood is fine.
ANy ideas?
rudydapimp
Copper - Posts: 390
Posted: December 17, 2006 at 7:19 AM / IP Logged
ht orange is dimmer. Yellow should be 12v constant. Red is the 12v switched. make sure that you don't have a fuse inside the truck and make sure that it is wired up correctly
cntrylvr79
Silver - Posts: 582
Posted: December 17, 2006 at 8:51 AM / IP Logged
I think he's talking about the car side of the ignition wire which is yellow.  Check the fuse panel on the drivers side of the dash.  I beleive the fuse for ignition power to the radio is in there.
Cause I'm So white and nerdy...
First Class Certi-fried installer
bentleyrb
Posted: December 17, 2006 at 8:56 AM / IP Logged
Thanks. Appears to be missing the fuse there
on the dash side fuse panel.
