recommend small amp?
urist
Posted: December 30, 2006 at 10:22 AM / IP Logged
Can you recommend small amp. instead of factory one in Ford?
I need amplifier for subwoofer, instead of factory amplifier 2ch 2x65Wt.
Do you know another aftermarket 2-ch. amplifier with dimensions LESS then 15x15x5cm?
aznboi3644
Gold - Posts: 2,600
Posted: December 30, 2006 at 5:00 PM / IP Logged
http://www.alpine-usa.com/en/products/product.php?model=PDX-4.150&lang=en&tab=F
urist
Posted: December 31, 2006 at 7:50 AM / IP Logged
Too large. I need less then 15x15x5 cm
Alpine dimensions :
  • Heat Sink (WxHxD) in: 10-1/8" x 7-9/16" x 2-7/16"
  • Heat Sink (WxHxD) Dimensions
    • Heat Sink (WxHxD) mm: 257mm x 192mm x 62mm mm: 257mm x 192mm x 62mm
specialaudio
Copper - Posts: 58
Posted: January 14, 2007 at 12:19 PM / IP Logged
Mayb the older jbl bp 150.1...
Output Power
Bridged Power (Watts x Channels): 150 x 1
Power at 2 Ohms (Watts x Channels): 150 x 1
RMS Power Output (Watts x Channels):75 x 1
Size
8-3/4"W x 8-1/8"D x 2-11/16"H
93' Cutlass
specialaudio
Copper - Posts: 58
Posted: January 14, 2007 at 12:22 PM / IP Logged
OR kicker Kx 75.2....
10.125" wide and it's about square (without the shroud).
93' Cutlass
