’06 nissan sentra se-r spec v w/ r-f
nytrdr24
Posted: January 14, 2007 at 1:03 PM / IP Logged
I have an '06 sentra se-r spec v with the factory rockford fosgate stereo that comes with the 8" sub in the trunk. I am wanting to install an extra amp & sub (profile cali ap1200 & polk momo 12), but am unsure to how to wire in the amp while keeping the factory head unit. Do I install one of the rca jack converters behind the deck , or can I tap into the wiring on the factory amp mounted in the trunk, the amp has both line level & rca hook ups, either way a wiring diagram for the stereo of this vehicle would be very helpful along with any advice you all could provide.
Awesome site, Thanks in advance for the help!
'06 Blk. sentra se-r spec v
'04 Blk/slvr cbr600rr
'93 Mazda b2200
KarTuneMan
Platinum - Posts: 7,056
Posted: January 14, 2007 at 1:18 PM / IP Logged
You can install your hi to low device at the amp....just make sure your on the INOUT side of the amp...NOT the output side. Look for these colors of wires going into the amp, these are "inputs"
Left Front + Red Line level output
Left Front - PURPLE / red Line level output
Right Front + Green Line level output
Right Front - RED / blue Line level output
Left Rear + YELLOW /GREEN
Left Rear - WHITE/ orange
Right Rear + RED / black
Right Rear - Gray/blue
nytrdr24
Posted: January 14, 2007 at 2:35 PM / IP Logged
Thank you very much!!
When I can manage to get some time off of work, I'll put my amp & sub in.
'93 Mazda b2200
