Sony CDX-GT200, aux in options?
shrug53
Member - Posts: 22
Posted: January 15, 2007 at 6:38 PM / IP Logged
OK here is the situation. I have a Sony Xplod CDX-GT200
The only AUX input it has is a 3.5 mm jack on the front panel. Nothing on the back.
I also have a DVD player with AUX out. I could just get an adaptor cable to plug the RCA in to the 3.5 mm jack but I was wondering if there was a cleaner way to do it without changing head units.
Any ideas?
ben23
Posted: January 16, 2007 at 7:57 AM / IP Logged
not really, unless u wanna rip open ur head unit, unsolder the socket, drill a hole at the back of the case, mount the socket, and solder wires from the socket to the pcb where the socket was
-Ben
imseth85
Copper - Posts: 71
Posted: January 22, 2007 at 11:25 PM / IP Logged
you could use an fm modulator...if it's just for a dvd and you don't need perfect sound quality it will work great and you won't see any wires.
Seth Alvo     NY
Mobile Electronics Installer
shrug53
Member - Posts: 22
Posted: January 23, 2007 at 4:30 PM / IP Logged
That is a great idea. I found an inexpensive Jensen one on Ebay I just bought. The only drawback is that I have to wire a toggle switch to the power to let my antenna feed come through.
