06 toyota avalon, stereo wiring
pitoaudiovisual
Copper - Posts: 388
Posted: January 22, 2007 at 2:59 PM / IP Logged
Does anyone have the radio wires diagram for a toyota avalon the one with the JBL system in it thanks in advance..
Confidence is the key to any project!!
KarTuneMan
Platinum - Posts: 7,056
Posted: January 24, 2007 at 11:49 PM / IP Logged
9, or 12 speakers?
pitoaudiovisual
Copper - Posts: 388
Posted: January 25, 2007 at 7:00 AM / IP Logged
Im pretty sure its the 9 speaker one.
weedel
Posted: January 25, 2007 at 11:15 AM / IP Logged
there is no way to install a new radio and just splice into speakers wires. in that car there is a data communication between the factory head unit and amplifier. metra makes a piece called a tyto-01 that will allow you to install a head unit and tie into the amp via rca pre amps. your head unit will have to have a front and rear preamp. also you may have to change the ground point in the car to eliminate radiated noise.
