mixed mono amp , passive crossover
grozanc
Posted: May 07, 2007 at 11:18 PM / IP Logged
I have been out of the loop for a while so forgive my question.
I have a PPI PCX280 (80w x 2) amp that I want to run in mixed mono. Currently the amp is running a MB Quart 3-way component (Tweeter, 4"mid, 5.25"woofer) with a passive crossover. I'm assuming the amp is seeing a 4ohm load.
I want to add a subwoofer and I need to get a low pass passive crossover but I'm a little confused. Running mixed mono is going to give me 80w x 2 and 320w x 1. That 320w is way too much power.
I have searched all over the internet and couldn't find a premade low-pass crossover so I willing to custom build one but I'm not quite certain what kind of passive crossover is going to lower the frequency to 100mhz but also reduce the watts to the woofer so it's not over powering the system?
aznboi3644
Gold - Posts: 2,600
Posted: May 07, 2007 at 11:33 PM / IP Logged
Well the amp will not put out 80 watts per channel AND 320 watts bridged and split that power between all of the speakers
It will put out the rated rms power at 4 ohms bridged.
refer to the "passive crossovers" link on the left of the site to find out what milli-henry coil you want for the desired low pass crossover point.
grozanc
Posted: May 07, 2007 at 11:47 PM / IP Logged
If I understand you correctly I'll be getting a total of 320w not 480w (80w x 2 and 320w x 1). So I will be getting 80w x 2 and 160w x 1?
I read the crossover section and know what type of coil I need but how do I limit the watts/power/volume to the sub with the crossover?
From what I gathered, all the passive crossover does is limit the frequency not the watts/power/volume. So if the sub is over-powering the components how do you adjust for that with a passive crossover network?
DYohn
Platinum - Posts: 10,741
Posted: May 08, 2007 at 12:37 AM / IP Logged
You can't.  And you will need more than just a low-pass crossover for the sub, you need to match the frequency and create a high-pass for the mains.  Running in tri-mode like this is generally only recommended as a stop-gap measure until a dedicated subwoofer amp can be installed, and only recommended with amps designed for tri-mode operation.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
