how do i calculate system load?
may03lt
Copper - Posts: 55
Posted: June 17, 2007 at 1:30 PM / IP Logged
Hey dudes! Im planning for the second (and hopefully last) part of my little system. As far as I know I do not have any charging issues right now with the factory charging system in my 03 Trailblazer with the system I have now and the way the sub amps are wired. I had a dmm hooked up to the alt with the a/c, lights, and system on, and did not go below 13.9v with my current set up.
Current set up:
(2) RF P8002 (4ohm stereo/ 120A each)
MTX 8302 (2ohm stereo/ 60A)
Alpine 9857 (10A) Kicker KX3 (10A)
New set up:
(2) RF P8002 (4ohm bridged/120A each)
MTX 4122 (4ohm stereo/ 20A)
What is the proper way to determine the load of the system, and how can I use that to determine what upgrades may be needed in the charging system?
Thanks!
may03lt
2003 Trailblazer LT
2007 Envoy SLT
may03lt
Copper - Posts: 55
Posted: June 18, 2007 at 2:46 PM / IP Logged
Ill put it another way:
Will my factory electrical system be able to keep up with 2,300 wrms?
If not what should be the next step?
2003 Trailblazer LT
2007 Envoy SLT
may03lt
Copper - Posts: 55
Posted: June 19, 2007 at 7:28 PM / IP Logged
hmmmm
searched the topics
didn't find the answers
asked the questions
got nothing
cant anyone point me in the right direction?
come on its good karma if ya dohow do i calculate system load? -- posted image.
wheres the love?
may03lt
2003 Trailblazer LT
2007 Envoy SLT
jmelton86
Gold - Posts: 1,228
Posted: June 19, 2007 at 7:35 PM / IP Logged
Figure out load on amp here:
https://www.the12volt.com/caraudio/woofer_configurations.asp
Do the Big3 Upgrade:
https://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
The next step would be a red top [or two - in parallel straight wired to each other (no isolator or circuit breakers)] and a high-output alternator.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
may03lt
Copper - Posts: 55
Posted: June 20, 2007 at 8:22 PM / IP Logged
Thanks bro!
See this is where I'm stumped - if the amplifiers are pulling 170A (I used the RF amp calculator that I never knew existed)  why would I need 2 batts? Would I just need an alt that will support the truck and the amplifiers? I will never listen to it without the truck running, that why I ask.
2003 Trailblazer LT
2007 Envoy SLT
zhalverson
Copper - Posts: 180
Posted: June 21, 2007 at 1:49 AM / IP Logged
Yeah, an alternator that can keep up is all you really need as long as your battery is in good shape.  2 batteries would only really help if you were listening to it off which you said you wouldn't be doing.
may03lt
Copper - Posts: 55
Posted: June 21, 2007 at 8:48 PM / IP Logged
ok, so should I take the requirements of the truck and add 170 to determine the amperage of the alt? And how do I figure what size battery to get?
2003 Trailblazer LT
2007 Envoy SLT
jmelton86
Gold - Posts: 1,228
Posted: June 21, 2007 at 9:13 PM / IP Logged
Yes, that is the proper way to determine what size alt to get. Just get a Red or Yellow top battery. Make sure to do the Big3 Upgrade with alt upgrade. It may void the warantee on the alt if you do not.
Big3 in 1/0G
1/0G to GTO14001
zhalverson
Copper - Posts: 180
Posted: June 22, 2007 at 12:52 AM / IP Logged
Like I said if you're existing battery is in good shape you don't need a different one and if you're not running the stereo while you're vehicle is off you don't need anything bigger than what you have because the alternator will provide the power.  No need to waste money in my opinion.
aznboi3644
Gold - Posts: 2,600
Posted: June 22, 2007 at 5:23 PM / IP Logged
An extra battery will help if your alternator can keep it charged.
When there is a big load on the alt and the voltage drops fast...the voltage won't drop as low if you have another battery to help support that draw
