overpowering speakers
kungwaz
Member - Posts: 16
Posted: July 18, 2007 at 9:03 AM / IP Logged
I am running infinity speakers with rockford amp.
My setup:
P4004 amp
one speaker to each channel (all rated at 2 ohm)
My question is; one pair of speakers are rated at 55W RMS and the others at 110W RMS that goes to the P4004 wich is rated at 4x100W RMS @ 2 ohm, do I have to set the gain on the lower rated speakers lower then on the higher rated speakers, so I can make it loud without blowing the weaker speakers?
// KungWaz
xtremej
Gold - Posts: 1,440
Posted: July 18, 2007 at 9:35 AM / IP Logged
Are you saying you have 2 ohm voice coils on the speakers?
kungwaz
Member - Posts: 16
Posted: July 19, 2007 at 1:16 AM / IP Logged
The impedance is 2 ohm on the speakers.
// KungWaz
jmelton86
Gold - Posts: 1,228
Posted: July 19, 2007 at 2:52 AM / IP Logged
kungwuz wrote: do I have to set the gain on the lower rated speakers lower then on the higher rated speakers?
Exactly. By having twice the RMS power available for the front speakers, you'll definately have to watch it with the gain knob. I recommend setting the gain on the rear ones first so you can roughly set it half of that for the fronts.
Always adjust gains slowly and you'll be good.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
kungwaz
Member - Posts: 16
Posted: July 19, 2007 at 4:13 AM / IP Logged
Ok, thanks I will !
// Kungen
// KungWaz
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
