sq amp selection
jurb
Member - Posts: 39
Posted: August 01, 2007 at 2:00 PM / IP Logged
Briefly: 2 TC-1000 15" in a sealed enclosure. I want this to be a pure sq setup and now I am looking for an amp. I've browsed the forum and seen that audiobahn gets crapped on while mtx and others get a lot of praise. I am wondering why this is...audiobahn has comparable SNR, and a 24dB/oct roll off versus others that have 12. Don't you always want the highest roll off possible? Any advice on amps or how to select for sq would be greatly appreciated. On another note, do you guys advise using polyfil? If so where do you buy it?
jvillefinest
Copper - Posts: 255
Posted: August 01, 2007 at 2:06 PM / IP Logged
SQ=money!
and if true power is usally a $ a watt...you do the math for audibahn.
try JL, focal, and eclipse. if you want to be real serious about SQ try and find amps that are A/B class for your subs. but bring your wallet for a good one!
2007 Acura TSX
SQ setup in the works
jurb
Member - Posts: 39
Posted: August 01, 2007 at 3:17 PM / IP Logged
Anybody know anything about the Kenwood KAC-X1R?
haemphyst
Platinum - Posts: 5,059
Posted: August 01, 2007 at 3:51 PM / IP Logged
Numbers don't tell the whole story. S/N can be the same, but the amps will sound completely different.
This is due to several differences:
IMD, or intermodulation distortion, a spec RARELY supplied, and determines how badly a fundamental is damaged when a second fundamental (or even a harmonic) is introduced to the same signal path.
Damping, or how well the amplifier damps (or shorts) the back-EMF generated by the voice coil.
THD. Frequency response, linearity...
Power supply capacity, a crappy power supply will not be able to keep up with the current demand, and this can be audible. (I might add that the power supply is ususally (or at least SHOULD be) the most expensive part of an amp. jville hit on it... SQ=MONEY!
Slew rate, or how fast the amplifer's devices can turn on or off.
There are other specifications that will come into play as well, but numbers (especially JUST S/N) will not tell the whole story.
Oh...! And chrome (and flame facsimiles) is (are) ALWAYS damaging to an audio signal, this is why you should NEVER allow chrome, flames, and ESPECIALLY chrome flames near an amplifier... This includes speaker baskets, rims, bumpers, rear-view mirrors, etc...
tcss
Silver - Posts: 1,623
Posted: August 01, 2007 at 7:09 PM / IP Logged
Dave, how  about the Alpine PDX-1.1000? It seems to meet all those criteria? Cough, cough......
There is no such thing as free installation!
haemphyst
Posted: August 01, 2007 at 9:34 PM / IP Logged
LOL
Yep, it meets them all quite nicely!
jurb
Member - Posts: 39
Posted: August 02, 2007 at 9:29 AM / IP Logged
So since a lot of those things are not generally listed, how can I find out about them?  I can't really affor more than $300, so I was thinking about the KAC-X1R which seems to be Kenwood's version of the PDX, what do you guys think of that amp?
