2004 chrysler pacifica, radio
dskemaite
Member - Posts: 25
Posted: October 10, 2007 at 4:00 PM / IP Logged
hi
i doing aftermarket radio on 2004 chrysler pacifica
i need to know where the factory amp located
and if i can run all the speakers from the radio without no amp.
thank
eddddddddddddiiiiiiiiiieeeeeeeeeeeee
perly
Copper - Posts: 155
Posted: October 13, 2007 at 8:26 PM / IP Logged
i have not worked on a pacifica but I do know that any chrysler that I have worked on which had a factory amp all I had to do was power the amp turn on and everything worked fine. I cannot find the wiring info for the car right now but if you are using a harness(which you definately should) then make sure you hook up the amp turn on from the harness to the amp turn on from your deck and everything will work
Saturday, November 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
