02 civic, getting sound noise
sotexcustomz
Member - Posts: 11
Posted: October 16, 2007 at 12:48 PM / IP Logged
from my system in my 02 civic,  ive replaced all my speakers tried 3 differnt radios 3 differnt amps  checked all my grounds and replaced my rca cables and its still wining with the engine. i checked the alternator and its putting out 14.5 volts no the rca cables are not on the side as the power wire and my grounds are all good going to the frame
the only way i can get the noise to stop is by touching the rca jack on the back of the radio to ground. i dont know why but it makes it stop and i can bearly hear it. but i know thats not right so wth?? its driving me crazy
this has only been happning for the past 3 days and i never touched anything on the system till it started
sarcomax
Copper - Posts: 276
Posted: October 16, 2007 at 1:54 PM / IP Logged
pioneer radio?
sotexcustomz
Member - Posts: 11
Posted: October 16, 2007 at 2:02 PM / IP Logged
yea all of them
haemphyst
Platinum - Posts: 5,059
Posted: October 16, 2007 at 2:35 PM / IP Logged
It's the "Pioneer Problem", rearing it's ugly, UGLY head again... Try a good radio, and by "good", I mean a "respected" radio; Alpine, Eclipse, Denon...
Pioneers have a known ground plane issue in them, and I don't understand why they won't fix it...
sotexcustomz
Member - Posts: 11
Posted: October 16, 2007 at 3:47 PM / IP Logged
i dunno why it would just start actin up so i get a new radio and it does it to, i guess i will go with an alpine this time
Platinum - Posts: 13,725
Posted: October 16, 2007 at 6:00 PM / IP Logged
If touching the shield of the RCA cable to the chassis of the radio makes it stop.  How about if you try this, solder a wire to the sheld of the RCA cable and ground the other end of the wire to the ground wire of your radio.  Just a hunch but it might work.
jmelton86
Gold - Posts: 1,228
Posted: October 16, 2007 at 6:45 PM / IP Logged
Yep. I've "fixed" a couple Pioneer radios like this.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
sotexcustomz
Member - Posts: 11
Posted: October 16, 2007 at 10:04 PM / IP Logged
well i put in a jvc that my buddy had laying around and it stopped completely. wth why would the pioneer start doing that all of a sudden then i put a new pionner in and it does it right off... it worked with the rca grounded but i didint want to screw up the radio like that and then it didint get  it all out
sarcomax
Copper - Posts: 276
Posted: October 17, 2007 at 11:37 AM / IP Logged
Once you do the pioneer fix, you will probably never have another problem. As to why brand new ones have the problem, it has to do with the order that the power and rca's get connected...usually. I have had issues with pioneer decks that have had all rca's connected first, connected the power first, grew an extra set of laser guided hands and connected everything at the exact same time... I just have some presoldered rca's prepped and ready to go now, as we sell a ton of pioneer radios here.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
