amp problem
mista_g713
Posted: November 26, 2007 at 10:01 PM / IP Logged
my subs and 6x9s suddenly stopped working. i have a distribution block with built in amp display and volt display. the voltage is good but it displays zero amps. all the fuses are good and everything turns on. what could the problem be?
my system:  3way crossover with a 400w 2 ch and a 800w mono amps. 2 farad cap. 2 audiobahn subs and 4 infinity 6x9s.
haemphyst
Platinum - Posts: 5,059
Posted: November 26, 2007 at 11:02 PM / IP Logged
1: Head unit
2: Cheezy amplifiers that are, in fact, dead (based on the general lack of information, the vague power ratings, the inclusion of ANYTHING Audiobahn, I suspect this could be it...)
3: Dead crossover
4: Bad RCA cable(s)
The list goes on! Help us help you... What have you done to troubleshoot? Were there warning signs of impending failure, or did it quit all at once, all of a sudden? What are your head unit, amplifier, and crossover makes and models EXACTLY? Do you have any LOCs in the system?
We can't read your mind! amp problem -- posted image.
