harley davidson handlebar controls
wooddogg
Member - Posts: 14
Posted: October 24, 2009 at 3:24 AM / IP Logged
  havin issues with a 2000 harley electra glide classic, installed swix jvc module and cant get LEFT side to program, handle bars have been changed and a non-factory wire  extension was added but tests right continuity, voltage, all resistors are right values but will not work. right side is fine but does not test at all , no continuity or voltage but controls seek up and down as well as source, have taken apart left bar controls traced all wires ,,,,,,THIS EVEN HAS TECHS AT PERIPHERAL STUMPED, have so far spent about 7 shop hours on this and cant figure it out,has anyone had this happen either working on a harley or using the swix jvc steering control module cant use the universal control because no locating for remote eye of that unit, kit is not big enuff to drill above head unit,,,,,,,,,ANY HELP ON THIS ONE PLEASE          WOODDOGG  10-24-09
Platinum - Posts: 13,722
Posted: October 25, 2009 at 3:52 AM / IP Logged
Are there any common colored wires between the left and right controls?   How many wires to each control (left and right)?
wooddogg
Member - Posts: 14
Posted: October 26, 2009 at 2:26 AM / IP Logged
thx for responding asap,,,,there are 4 wires per stereo control,left and right side,the left controls volume up and down and pushing in the button controls audio,bass treb.ect.the only wire that seems to be common, is pink/white tracer  which is supposed to be cut and grounded,of the remaining wires the are connected with with resistors,,the wiring diagram i am using is from  swix programing and is for a  2000 harley davidson,model does not seem to be specific,so it must be a diagram covering a majority of harleys,,,i can try and send you a link to swix  but if you could look it up it would probably be faster,i`m a lil computer stupid,haha,,,,,  ANY HELP YOU COULD GIVE ME WOULD BE GREAT   thx wooddogg
Posted: October 26, 2009 at 6:08 AM / IP Logged
I searched briefly and came up with nothing.  Post a link if you can.
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
