thor motorcycle alarm
nite
Posted: January 13, 2010 at 11:38 PM / IP Logged
hey guys, i found this forum while googling around, finally a place where i cant talk about electronics!
anyways i own a 2003 yamaha r1 and i purchased a Thor motorcycle alarm pics below
the alarm works fine, i have the sirens working, but my problem is that i need to hook up the remote starter, and this is my concern, also i need to hook up the lights, so when the bike arms it will flicker the turn signals, i know if i hook up to one signal light it will only flash that one and not all 6 of them.
does anyone know how to hook the bike up so the remote starter works?
thank you
thor motorcycle alarm -- posted image.
nite
Posted: January 13, 2010 at 11:42 PM / IP Logged
sorry i did not realize i cannot edit my posts, this is the image i ment to post but accidently hit enter, sorry again i am on my netbook in the dark and cannot see properly lol
http://www.hsalarms.com/wiring.php thats the diagram i saw on a previous post btw
oldspark
Gold - Posts: 4,913
Posted: January 14, 2010 at 10:12 PM / IP Logged
What remote start circuit are you using?
The remote start in the diagram is for sensing only (to disable the alarm - at least so I assume) - not for issuing a start signal.
nite
Posted: January 14, 2010 at 10:38 PM / IP Logged
what do you mean by that? this is all it came with, the ridiculous instructions, i can provide a schematic diagram for my bike, that i can take from the repair manual if that helps?
oldspark
Gold - Posts: 4,913
Posted: January 15, 2010 at 5:51 AM / IP Logged
Sorry - I interpreted that you wanted to start it remotely.
Maybe that is the intention, but without neutral sensing, I'll bug out anyhow.
nite
Posted: January 16, 2010 at 11:14 AM / IP Logged
yes the bike will not start without it being in neutral, i wanted to start it remotely thats all
oldspark
Gold - Posts: 4,913
Posted: January 17, 2010 at 3:13 AM / IP Logged
So you connect the alarm's blue "connect to starter" wire to the starter wire (from the handlebar switch, or the relay that controls the starter-motor).
I presume the alarm will switch a relay only - not the starter-motor's solenoid. Check your wiring diag for a relay (not to be confused with the integral starter-motor solenoid if fitted), else check the supply capability of the alarm, though it looks like a few Amps if that - not enough for a starter motor nor its solenoid direct.
nite
Posted: January 24, 2010 at 3:25 PM / IP Logged
sorry for the late reply, so for the turn signals i would hook the wires to the handlebar switches right? because they turn the signals?
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
