motorcycle, N.O. relay
triutto
Posted: September 10, 2004 at 12:57 AM / IP Logged
Greetings i am new .I have a vintage motorcycle .I am installing a solid state ignition about 10 amps or 15 .I have a no switch I need a 12 volt relay that wont bounce open it has to have a N.O. set of contacts and fit in my head light .there is one in relays thsaat shuts the ignition off .were can i get such a relay jim jimt622@mindspring.com
hotwaterwizard
Silver - Posts: 1,350
Posted: September 10, 2004 at 6:54 PM / IP Logged
I think you need a solid state Relay it has no contacts to rattle around. Explain more please.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
triutto
Posted: September 10, 2004 at 8:01 PM / IP Logged
Thanks I need a 12vdc N.C splid state relay that can handle 5 amps goinh through the contacts.What I want to do is sent 12vdc trough the momentary open switch and put it on the pos of the relay coil and ground the other end of the coil .I then want to run the ignition through the contacts of the relay so when I push the momentaty switch it will energize the relay open the contacts and cut off the ignition. I dont think anyone makes a solid state relay that is 12vdc and has n.c. contacts .I am afraid to put a mechanicle relay in this system because of vibration .I dont want the circuit to open while I am riding the bike .this relay will be in the head light shell .do you have any ideas  jim
hotwaterwizard
Posted: September 12, 2004 at 10:05 PM / IP Logged
How about an SCR in the line that will Reset when the power is Cut?motorcycle, N.O. relay -- posted image.
Stockton California
triutto
Posted: September 17, 2004 at 6:19 AM / IP Logged
I am amazed .I just cant belive that there is not a 12 volt DC relay with a N.C contact that is not Solid state or like it .I have the siplest ckt in the world .The only thing is it has to be moisture proof N.C and  will not under any curcumstances bounce rattle or vibrate open when not energized.I have a momentery open switch .I want to push the switch thus energizing the relay and opening the ckt .(5 to 10 amps) .I choose a Solid state relay because of my 2 conditions ! it will be in the headlight of a motorcycle( vibration) and 2 its wet in there can any one help  Jim
hotwaterwizard
Posted: September 19, 2004 at 12:39 AM / IP Logged
Look at this.
http://www.magnecraft.com/products/section2_15_19-20.pdf
Stockton California
hotwaterwizard
Posted: September 19, 2004 at 1:01 AM / IP Logged
So you are looking for a solid state Relay with Normaly Closed contacts that open when power is applied?
Here is one such item.
and here is a supplier http://www.newark.com/NewarkWebCommerce/newark/en_US/endecaSearch/partDetail.jsp?SKU=94B7224&N=0
Stockton California
