dei hornet 564t stuck in timer mode
jj92sc
Posted: January 03, 2008 at 2:48 PM / IP Logged
I have a DEI Hornet 564T installed in my 92 saturn SC, and I've liked it thus far. It seems i'm having a bit of a problem now. For some reason, the unit is stuck in timer mode, where it starts my car every three hours for the programmed duration. In the instruction manual, the method for exiting timer mode is to turn on the ignition anytime the car is running, but that hasn't worked. I've tried using the method to put it into timer mode in the first place (push the lock and unlock buttons at the same time) to no avail. I've also tried triggering the brake, and door pins and that hasn't worked either. Any ideas?
Twelvoltz
Platinum - Posts: 2,384
Posted: January 16, 2008 at 5:32 PM / IP Logged
Did you have the system installed? Or did it come with the vehicle?
If it did, do you have what looks like an aftermarket clock installed in the vehicle?
jj92sc
Posted: January 16, 2008 at 7:24 PM / IP Logged
No, I installed it. No aftermarket clock. I never did figure out the problem, so I disconnected the battery and apparently that reset it.
mrjc480
Member - Posts: 44
Posted: January 16, 2008 at 9:48 PM / IP Logged
If you hold the LOCK and the AUX down it will enable/disable the timer.
Im moving to MEXICO and Im not speaking spanish!
Sunday, November 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
