Is Key Sense Wiring Necessary? 05 Ford Escape
red85
Member - Posts: 31
Posted: January 05, 2008 at 7:56 PM / IP Logged
i am something of a newbie here, so bear with me.  I have just gone through some training with ProStart (Auto Start) and I've been going over some wiring guides.  Is it absolutely necessary to supply power to a keysense wire (+ polarity) if I am using a bypass module?  If I have to supply power to this wire, where should I take it from? Ignition or accessory (1 or 2)?  Thanks for your help in advance
Phil
chadwa2003
Copper - Posts: 353
Posted: January 05, 2008 at 11:20 PM / IP Logged
What kind of vehicle and bypass module are you using?
red85
Member - Posts: 31
Posted: January 06, 2008 at 5:47 AM / IP Logged
05 Ford Escape and a TB-350 (AutoStart) bypass module.  I can't remember if that keysense wire is + or - polarity.  At any rate, what is the rule of thumb here?  If it's a - do I use the ground out while running connection on the r/s module?  If it's + where should I supply the power from?
Chris Luongo
Platinum - Posts: 3,746
Posted: January 06, 2008 at 9:08 AM / IP Logged
It seems that all the tech sheets these days list the car's keysense wire, whether it's needed or not. Most of the time, it isn't necessary.
And you asked about rule of thumb? You'll get a lot of different opinions.
My rule of thumb:
Older Saturns need keysense, or the check engine light comes on. Toyotas that have factory alarms need keysense, or the alarm will go off.
On European cars, it's wise to power up ALL accessories, including keysense, because those cars can be so finicky.
Other installers' rule of thumb:
Power up as many circuits on the car as you can, to duplicate factory operation as best you can.
Ford Escape:
I only connect three wires at the ignition switch: Constnat, Ignition, and Starter. This way, not only is the job easier, but the radio remains off during remote start.
Other installers not only power up the radio, but they use the remote starter's Ignition 2 output to the car's keysense wire. In this way, it's 100% like factory, and guaranteed to work right the first time.
red85
Member - Posts: 31
Posted: January 06, 2008 at 9:00 PM / IP Logged
Thanks for the reply!
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
