2003 suzuki aerio wiring
Reeceddogg
Copper - Posts: 331
Posted: January 06, 2008 at 2:54 PM / IP Logged
Looking for wiring info on this car. 2003 SUZUKI AERIO
Twelvoltz
Platinum - Posts: 2,384
Posted: January 06, 2008 at 2:57 PM / IP Logged
Audiovox Lists:
          #8550: 2003 SUZUKI AERIO 4DR SEDAN
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          WHITE/ BLACK          (+)          RADIO HARNESS
     Accesory          WHITE/ RED          (+)          RADIO HARNESS
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          RED / YELLOW          (+)          RADIO HARNESS
     LF Speaker (+)          BLUE/RED
     LF Speaker (-)          BLUE/BLACK
     RF Speaker (+)          YELLOW /GREEN
     RF Speaker (-)          YELLOW/BLACK
     LR Speaker (+)          GRAY/RED
     LR Speaker (-)          GRAY/BLACK
     RR Speaker (+)          LIGHT GREEN/ RED
     RR Speaker (-)          LIGHT GREEN/ BLACK
     Steering Cntrls          NO
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          WHITE/ GREEN          (+)          IGNITION SWITCH HARNESS
     Ignition 1          GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK/ RED          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          BLACK / YELLOW          (-)          IN DRIVER'S KICK PANEL
     Domelight Super          BLACK/ RED          (-)          IN HARNESS IN DRIVERS KICKPANEL
     LF Latch          BLACK / YELLOW          (-)          AT DOOR PIN SWITCH HARNESS
     RF Latch          BLACK/ RED          (-)          AT DOOR PIN SWITCH HARNESS
     LR Latch          BLACK/ RED          (-)          AT DOOR PIN SWITCH HARNESS
     RR Latch          BLACK/ RED          (-)          AT DOOR PIN SWITCH HARNESS
     Parking Lights          RED / YELLOW          (+)          IN DRIVER'S KICK PANEL
     Convenience
     Please select another category
     Remote Start
     Accessory 1          YELLOW/BLACK          (+)          IGNITION SWITCH HARNESS
     Tachometer          L.GREEN/ BLACK          (AC)          ECM PIN 2
     Speed Sense          PURPLE          (AC)          AT 3 WIRE CONNECTOR AT THE TRANSMISSION
               CAN ALSO BE FOUND AT THE ECM. THE ECM IS LOCATED BEHIND GLOVE BOX ABOVE KICK PANNEL, PIN 27
     Brake Lights          GREEN / WHITE          (+)          AT SWITCH ABOVE PEDAL
     Horn          BLUE/LIGHT GREEN          (-)          AT STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Module 1          ECM - BEHIND GLOVE BOX ABOVE KICK PANEL
     Doorlocks/Windows
     Power Unlock          GREEN/ ORANGE          (-)          IN DRIVER'S KICK PANEL
               PIN #9
     PowerLock          BROWN / WHITE          (-)          IN DRIVER'S KICK PANEL
               PIN #8
     LF Window Up          RED          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     LF Window Dn          GREEN          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Up          RED / WHITE          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Dn          GREEN / WHITE          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Up          RED / YELLOW          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Dn          WHITE          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Up          WHITE/ RED          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Dn          WHITE/ GREEN          (REV)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Tuesday, December 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
