mar 22 remote start
russbm
Member - Posts: 46
Posted: January 07, 2008 at 8:12 PM / IP Logged
Anyone install a Mar 22 Remote start on a 1996 Toyota Camry I got it to work but it wouldn't turn on the heat or the air condition. When you start the car normally the heat or air work ok. Just can't figure why when it set  to heat the car when I click on the remote start it won't turn on the heat or air but the car start ok.
Twelvoltz
Platinum - Posts: 2,384
Posted: January 07, 2008 at 8:17 PM / IP Logged
Did you power both the BLACK / YELLOW and the BLACK/ orange ignition wires?
russbm
Member - Posts: 46
Posted: January 07, 2008 at 8:45 PM / IP Logged
it doesn't count for the ignition 2 wire I just wonder if the white is the problem i might of forgot to hook the white wire.
