99 windstar stick in anti theft
red85
Member - Posts: 31
Posted: January 12, 2008 at 12:26 PM / IP Logged
I have a 99 Winsdstar stuck in the shop right now and it is stuck in antitheft mode.  Is there a way to reset this?  This vehicle only has one ignition key available and a blank key that was supposed to be programmed for a bypass module in a remote starter.  I am fairly certain that this key was not programmed and it has somehow put the vehicle into anti theft.  I have removed all connections to the remote start and attempted to start the vehicle with the regular key but have had no success.  Any and all help would be greatly appreciated
tedmond
Gold - Posts: 4,610
Posted: January 12, 2008 at 9:04 PM / IP Logged
place key into ignition, turn to run, open driver door and wait for 15 min. after 15 min, try to start. if it doesnt start, leave it for another 10 - 15 so it can relearn the resistance. If taht doesnt work, double check all the fuses.
red85
Member - Posts: 31
Posted: January 12, 2008 at 9:19 PM / IP Logged
Thanks tedmond.  That's good to know.  Does that apply to most Ford vehicles with antitheft?
tedmond
Gold - Posts: 4,610
Posted: January 13, 2008 at 9:02 AM / IP Logged
this will work on ALL CARS that use the RESISTANCE antitheft. so passlock 1, passlock 2, vats.
