07 honda civic viper 791xv remote start
Johnnynguyen20
Copper - Posts: 89
Posted: January 15, 2008 at 10:26 AM / IP Logged
hello, i wonder if the Viper 791XV remote start/alarm system will work for this 07 honda civic. some other posted said new Civic like 06-08 need to use the alternator stator sense wire in order to remote start at 30 degree below.  the Viper 791XV  doesn't have the mode alternator sense voltage.
Johnnynguyen
Platinum - Posts: 12,488
Posted: January 15, 2008 at 5:07 PM / IP Logged
IT will depend if the Viper system likes the injector signal. The Compustar systems do not like the signal coming from the injectors, that is why it is suggested to use the alternator sense wire instead.
JWorm
Platinum - Posts: 2,208
Posted: January 15, 2008 at 5:24 PM / IP Logged
DEI systems prefer an injector signal. You should be fine using it.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
