door unlock/lock
bizzy818
Copper - Posts: 60
Posted: February 26, 2003 at 11:04 PM / IP Logged
How do I add a unlock/lock t my alarm system? Were is a good place to put the alarms shock sensor? Were does the alarms iginition wire 1 and 2 go?
draasch
Gold - Posts: 2,172
Posted: February 27, 2003 at 5:08 AM / IP Logged
First you need to tell us what the yr,make and model of the car.
David
bizzy818
Copper - Posts: 60
Posted: February 27, 2003 at 4:31 PM / IP Logged
I HAVE A 94 HONDA ACCORD EX. THNX
bizzy818
Copper - Posts: 60
Posted: February 27, 2003 at 4:32 PM / IP Logged
David
94 HONDA ACCORD EX
Platinum - Posts: 12,488
Posted: February 27, 2003 at 5:44 PM / IP Logged
POWER LOCK|BLACK/ white         |-  |gray conn. above fuse
POWER UNLOCK|orange              |-  |box in blue tape
You do not need to hook up 2nd ignition on an alarm system. The primary ignition is BLACK / YELLOW at the ignition harness.
bizzy818
Copper - Posts: 60
Posted: February 27, 2003 at 7:55 PM / IP Logged
where is the box in blue tape at?
and you know alarms have 1st ignition and 2nd were do these go? were is the ignition harness? thanks you helped alot.
draasch
Gold - Posts: 2,172
Posted: February 27, 2003 at 8:39 PM / IP Logged
Constant 12 volts WHITE IGNITION SWITCH HARNESS(FUSED 50 AMP)
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE/ SILVER (-) GRAY MOLEX TO RT. OF STEERING COLUMN
Trunk Pin Switch ORANGE (-) AT LIGHT
Parking Lamp RED / BLACK (+) ABOVE DRV KICK-20 PIN BLUE CONN PIN 6
Power Lock BLACK/ WHITE 2 PIN PLUG, TAPED TO WIRING
Power Unlock ORANGE HARN. ABOVE FUSE BOX #201
#201- See Negative Pulse Door Lock Diagram.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
