What diode do I use with hood pin autopag
bog1e
Member - Posts: 6
Posted: February 27, 2003 at 4:45 AM / IP Logged
Sup guys I just had a quick question for ya. In the autopage 750lcd installation manual it says to use a diode for the hood pin switch and also for the instant trigger wire. I just need to know what type of diode to use with this application. Thanx doodz! What diode do I use with hood pin autopag -- posted image.
Platinum - Posts: 12,488
Posted: February 27, 2003 at 5:27 AM / IP Logged
If it's only a grounding activation use a 1N4001 1 amp diode.
draasch
Gold - Posts: 2,172
Posted: February 27, 2003 at 5:28 AM / IP Logged
you can use a 1 or 2 amp diode. make sure you put the cathode side towards the hood switch.
Good luck,
david
bog1e
Member - Posts: 6
Posted: February 27, 2003 at 5:47 AM / IP Logged
Man you guys are fast yo. Thanx a lot, ohh and if you guys have any pointers for me, please let me know, since this will be my first install. Thanx.
jduncan_69
Posted: February 27, 2003 at 11:28 PM / IP Logged
Just to let ya know, all the autopages that I have done have a BLACK/ white wire on them that have to be grounded if not in use for the remote start to work.
Jason
bog1e
Member - Posts: 6
Posted: February 28, 2003 at 5:45 AM / IP Logged
Schweet I am pretty sure I know which wire your talking about.
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
