bypass module for 05 nissan altima
jmacf14
Copper - Posts: 160
Posted: February 02, 2008 at 9:01 PM / IP Logged
Hi, can anyone tell me what the best bypass module for a 2005 altima 2.5s would be?. I am wanting to install a ultrastart r/s alarm in it , and need to know if it needs a bypass, and which is best.
jmacf14
jmacf14
Copper - Posts: 160
Posted: February 02, 2008 at 9:17 PM / IP Logged
I am thinking the can- sl2 from idatalink, or the bypasskit xk02, from what I have read, the can-sl2 is the better route. Any oppinions?
jmacf14
Chris Luongo
Platinum - Posts: 3,746
Posted: February 02, 2008 at 10:47 PM / IP Logged
XK02 isn't for trasponder bypass, it's for doorlocks. And that car's so easy to do locks/trunk on, I think a module's a waste of money. The search feature should help you find how to do locks without even going into the door.
XK07 works fine for transponder bypass, but be sure to buy from a seller who's smart enough to ship it to you with the right firmware already in it.
CAN-SL-2 should work just as well as XK07, and has more features......I think it'll do the locks too.........kind of like having an XK02 and an XK07, all in one, for the same price as an XK07.
The CAN-SL-2's tach output is nice, but it's not reliable.
jmacf14
Copper - Posts: 160
Posted: February 03, 2008 at 2:13 PM / IP Logged
Thanks for the input Chris, I think I will go with the idatalink module because it does cover all the bases. Thanks again.
jmacf14
dswift
Copper - Posts: 396
Posted: February 04, 2008 at 6:54 PM / IP Logged
fyi
cansl2 is fortin
ads-dlsl ca would be your idatalink piece equivilant to the cansl2
"dont ground out!"
tedmond
Gold - Posts: 4,610
Posted: February 04, 2008 at 9:34 PM / IP Logged
yeap, dswift is correct. i think you kinda lost yourself, but its all good, we all make mistakes =)
jmacf14
Copper - Posts: 160
Posted: February 05, 2008 at 9:57 PM / IP Logged
thanks for your input guys, I was just reading info on another web site, and I think their info was misleading. Thanks for setting me straight. I found the idatalink web site, and found what I was looking for there. Thanks again.
jmacf14
