astrostart tach learning
dsorensen11
Member - Posts: 18
Posted: February 04, 2008 at 1:13 PM / IP Logged
I am installing an RSS-5224 remote starter into a 2006 Toyota Tundra Double Cab. Start function seems to work fine but I cannot get it to Tach learn. When I run the tach learn, the led just starts flashing indefinitaly. The engine cuts out when RPM's reach 3000, so I assume it is seeing the tach signal ok. I went to one of the injectors for the tach signal. Any thoughts?
KarTuneMan
Platinum - Posts: 7,056
Posted: February 04, 2008 at 6:50 PM / IP Logged
Does the unit start 1st time everytime without any grind?  Astro shows the tach as black behind the guage cluster, 8 cyl. reading.
If so.....your done. The engine is supposed to stop at 3 grand. Theft prevention.
dsorensen11
Member - Posts: 18
Posted: February 05, 2008 at 12:12 PM / IP Logged
Hey KarTuneMan,
Engine seems to start fine everytime so far with no grind. I went to one of the injectors for the tach signal. Maybe I should move it to the tach wire behind the instrument cluster. I assumed that it was getting a good tach signal or it would not shut the engine down @ 3000rpm. I believe this is the over-rev protection kicking in. I just cant figure out why the tach learn option does not work. Any chance that moving it to the tach wire in the cab will help?
saskpuller
Copper - Posts: 144
Posted: February 06, 2008 at 1:13 AM / IP Logged
Everything is good. I noticed that the new RSS series from Astro seem to program alittle different than the old series. The outcome is still the same. Leave things alone
dsorensen11
Member - Posts: 18
Posted: February 06, 2008 at 2:25 PM / IP Logged
Thanks Saskpuller. Have you found that the new RSS's have any better distance than the old 4204's?
KarTuneMan
Posted: February 06, 2008 at 6:06 PM / IP Logged
Explain that would ya. The only units I seem to use are the RSS 2504's and they are identical to the older astro's.
They do have stage 2 programming, but thats been around for a while.
tonyberg
Copper - Posts: 116
Posted: February 06, 2008 at 6:31 PM / IP Logged
The RS series is definitely different than the old stuff, even though the RS623 has dipswitches the programming tables are different
saskpuller
Copper - Posts: 144
Posted: February 06, 2008 at 10:21 PM / IP Logged
I noticed that on the rss623, the tach programming behaved different. No clicking of the module. Not a big deal. Also had to hit the brakes before programming transmitters. Also the tables are different. Not sure on a difference of range as I can't/don't test that.
