2007 civic ex compustar p2w900fm as
hyisbm
Member - Posts: 17
Posted: February 23, 2008 at 10:19 AM / IP Logged
okay, I've had this installed on my car for about three months now. When it's working, it's just about perfect. But the issue I have now is sometimes it doesn't lock/unlock the car doors. Also, it will show that the door is open. This is the third time it has happened. The first time we took it back and the installer reprogrammed the brain and remotes. Worked for about a week or so then it happened again. This time the installer swapped out the brain. Again, the same issue is back. After the time he swapped out the brain, he mentioned that one of his friends had the same issue with a new Honda and that idatalink had to write him a program to flash the module. Any one had to do this or know about this? Thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: February 23, 2008 at 9:00 PM / IP Logged
Use the dome light wire for door trigger. It's pink. I have an 06 and got the same (had) the same problem.I have not used any idata product.....it's not quite refined enough for me.
hyisbm
Member - Posts: 17
Posted: February 24, 2008 at 11:36 AM / IP Logged
okay, I'll talk to my installer and see which wire he tapped for the door trigger then suggests this idea to him. Thanks
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
