door locks on 2008 tahoe
robh415
Member - Posts: 8
Posted: March 15, 2008 at 8:49 PM / IP Logged
I just added a python 990 and used a directed 1701G bypass kit.  When I press the unlock only the driver's door unlocks.  I tried to press twice, It is set on double pulse.  We just about tried every setting there is that involves the door locks.  Has anyone seen this before or can anyone gve an idea.  Thank you
dtk1
Copper - Posts: 179
Posted: March 15, 2008 at 9:41 PM / IP Logged
check there are 2 wires one is for unlocking dirver side ONLY (blue and back) and the other one is LT.blue this is the main wire to unlock driver and all the other doors check those wires
robh415
Member - Posts: 8
Posted: March 15, 2008 at 10:39 PM / IP Logged
That worked. Thank you
Do you know if I wanted the glass hatch to open, Do I need a relay or anything special?  The original factory remote had that option.  Thank you
Thack79
Silver - Posts: 526
Posted: March 31, 2008 at 10:38 AM / IP Logged
yeah you need a relay too coming from the aux connection of the alarm
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
