2005 nissan altima, door locks
2003kawasaki
Member - Posts: 20
Posted: March 27, 2008 at 7:56 AM / IP Logged
What type of door locks are in a 2005 nissan altima? I'm looking to install a relay setup to unlock the drivers door first. Then all door after.
tedmond
Gold - Posts: 4,610
Posted: March 27, 2008 at 10:11 AM / IP Logged
here you go.
2005 nissan altima, door locks -- posted image.Driver Mtr Unlock GREEN/ RED (REV) IN HARNESS IN DRIVER KICKPANEL
2005 nissan altima, door locks -- posted image.Driver Mtr Lock YELLOW/RED (REV) IN HARNESS IN DRIVER KICKPANEL
2005 nissan altima, door locks -- posted image.Pas Mtr Unlock GREEN / WHITE (REV) IN HARNESS IN PASSENGER KICKPANEL
Chris Luongo
Platinum - Posts: 3,746
Posted: March 27, 2008 at 2:50 PM / IP Logged
Use your relay on the "driver motor unlock" listed on tedmond's diagram. That wire can easily be found at the car's BCM.
(To find the car's BCM (body control module), you can hear it click when you operate the locks.
Connect your factory-disarm output, AND your second-unlock output, to empty pin 14 at the BCM.
(Go to www.carsound.com/forum, and search for "nissan bcm" for a better explanation of the empty pins at the BCM.)
